[solved] Error converting using MTV Converter
Old 29th Mar 2006, 9:41 pm
Default [solved] Error converting using MTV Converter
Hi i have a problem i whant to put some movies on my mp4 when i convert whit mtv convertor it seys:
Error
No this type of CODE, connect AVI split filter and Bmp Grabbel filter faild!
OK
After it this
Please instal code for AVI
After this
Informetion
Faild to convert, try other code ?
Yes or No
When i sey yes it seys:
Agen error
No this type CODE, can not create MPEG-II Splitter filter!
Then conver comlpet.
Can you help me please ?
Old 30th Mar 2006, 12:21 am
Default Re: Hi i need help whit the error
Hi Whiper,
Welcome to the forum.
Firstly, please make sure you have installed the following firstly:
Uninstall the version you have installed on your computer at the moment. Now, I would suggest you download the MTV Convert Tool 3.06 (MP3 Player Utilities 3.06) from our site here instead and install it.
Once you install it, try converting to .MTV again and let me know what happens - whether it works or not.
Also, can you tell me what file type you are trying to convert into an .MTV please?
Old 31st Mar 2006, 10:46 pm
Hmm...
I donth have SLD Codec Pack 2.2
and i have mtv 3.14
I em trying to convert vidio clips or other typs.
Old 1st Apr 2006, 12:03 am
Whiper,
Ok, download SLD Codec Pack and install it on your computer then try to convert to .MTV again.
Have you tried the other steps mentioned? Like uninstalling and reinstalling our version from our site?
What "video clips" are you trying to convert? Are they .MPG, or .WMV or .VOB etc... files?? Which ones are they??
Old 2nd Apr 2006, 7:22 am
Were can i download it ?
And i em converting mpeg files or others.
Old 2nd Apr 2006, 2:02 pm
Whiper,
Move the mouse over my previous post of the "SLD Codec Pack 2.2" and u'll find it's actually a link.
Also, all our downloads are in the "Downloads" section on the left hand side navigational bar.
Hope that helps.
Old 3rd Apr 2006, 8:06 am
Tnx allot it helped naw i can convert it.
Old 4th Apr 2006, 1:11 am
Hey Whiper,
Great news.
So it's working ok now for you?
If this has been solved, can you please put a [solved] in front of your original post topic please?
3.68 amv converter error when converting mandamoses Video related 6 16th Dec 2007 8:05 am
AMV 3.68 converter not converting itspete Video related 2 2nd Mar 2007 3:33 am
[solved]disc full error when converting dvd to amv cv1 Video related 5 16th Sep 2006 4:58 pm
[solved] Converting software - "format error" Bhavesh Video related 3 3rd May 2006 6:22 pm
[solved] amv converter not converting Video related 4 29th Apr 2006 1:02 pm
