problem with my mp4 player
Old 12th Apr 2006, 1:56 am
wind
Guest
Posts: n/a
Default problem with my mp4 player
dear all,
i just bought a new mp4 palayer for few day agoooo.
the manual book say the storage from mp4 player must format in FAT type not in FAT32.
the question is why sometime mp3 and amv file is corrupt (cant play in from mp4palyer or from pc)when that file is already copy to mp4 palyer
wind
Old 12th Apr 2006, 2:34 am
Default Re: problem with my mp4 player
wind,
Have you tried formatting your player with the "MP3 Player Disk Tool" from the AMV Convert Tool 3.68 (MP3 Player Utilities 3.68)?
What you can also do is format the player from Windows using the "Disk Management" tool within Windows.
Try that and see if that solves the corruption problems?
Old 12th Apr 2006, 6:04 pm
wind
Guest
Posts: n/a
i had try format from pc use "Disk Management" but still same.....
before i post this thread
for information my mp4 player storage is 4GB, as i know FAT type max support is 2GB. should i partition storage mp4 player?
but i heven't try to format my mp4 palyer with amv convert tool 368 yet ....
couse i still confuse use this software .......
Old 22nd Apr 2006, 10:32 pm
wind,
Try formatting your player using the MP3 Player Disk Tool.
Just make sure you have your player plugged into the USB of your computer firstly opening the MP3 Player Disk Tool.
To format:
1. Choose the correct drive letter of your MPx player.
2. Under "Format Type", choose "Low"
3. Don't worry about the "Partition and Encrypt" tab
Actually, come to think of it, 4 Gigs is quite big actually. Can you send us a photo of your player to make sure it is an s1mp3 player? It might be totally different solution/board player, so all the instructions above might not actually work....
problem with my mp4 player. lordik Support and How To 1 6th Oct 2006 3:26 am
I have a very big problem! MP4 4G Player Csaba Dead Players 1 6th Sep 2006 2:49 am
my mp4 player 2gb problem BONESZ Mods and Themes 2 8th Aug 2006 4:40 am
My mp3 player problem Jeans Support and How To 1 7th May 2006 9:15 pm
