Problem: Resets on Move player option
Old 9th May 2006, 3:05 am
Default Re: Problem: Resets on Move player option
I formatted the player again, DL’d “over the hedge” and it played this time.
Then I encoded a few AMV’s and all of them crashed!
Then I tried encoding some more with low and medium quality settings and they All worked. I think I might have narrowed the problem down to the high frame-rate setting.
Old 9th May 2006, 3:20 am
The “over the hedge” sample file was encoded with "high" frame rate so it seem strange you can play it.
It sounds really like a memory issue with the flash memory in your player if it works and sometimes doesn't work.
cant get pm4 player to move on slayer101 Dead Players 3 24th Mar 2008 7:07 am
Mp4 Player - how to move screen? Hidendra Support and How To 2 14th Nov 2007 4:59 pm
Mp3 player utilities doesn't have disk tool option dele3rious Support and How To 1 2nd Aug 2007 7:58 pm
Record option doesn't work on TJD_1301_02 player masakupa Support and How To 3 5th Jul 2007 4:20 am
Music Player Option Fabs General Discussion 4 30th May 2006 2:03 am
