4th May 2006, 9:51 pm
Originally Posted by Sunny";p="
Hi Binh,
I have downloaded all but the pack for conversion purposes, did download 4.0 converter and Quicktimes still did not convert...so suppose need pack?
Downloaded Winamp/LRC Editor and gUSB plugin
Awaiting next steps regards viewing lyrics on player and being able to take lyrics from other sources to edit as I prefer..Way kewl!
Also suggested seller on Trademe post this website in his description box for all the disgruntled people unhappy with their players because many are not knowing how to work thru the issues thru or have access to the tools to get the best use out of their players...You guys rock!!! Thanks for being here and providing these resources & tools!! Good on ya!
Cheers,
Sunny
Sunny,
My suggestion is for you to sit down and spend alittle more time with the player to familise yourself with it.
With regards to your original post, you need to install the SLD Codec Pack then try converting to AMV. If that doesn't work, then use the RAD Tool to convert your Quicktime files to an AVI instead.
You've put a number of different problems in your previous post, I suggest create a new topic for each. But before hand, I would suggest you spend alittle time with the player firstly to familise yourself with it. Read up in the Knowledge Base, it might help you as well.
