Problem formatting
Old 15th May 2006, 1:24 am
Default Problem formatting
Hi All,
Can anyone help me with this, I have a MP4 Player of 512MB and i loaded around 100songs in it but when i play them after 30 songs its getting restarted automatically and starting from the first song, so i checked the solution for files geetting corrupted in the forum and tried formatting the palyer with MP3 Disk Tool i did a low format while formatting says read write area and after reaching 99% it gave a error
Error : RDiskutility.exe encountered problem and will be closed.Sorry for the inconvience send the error or dont send
When i click on ok my player is formatted and all the 512MB is freee but the problem is when i load the songs its paying only 30 songs
CAN ANYONE HELP ME WITH THIS Iam using win XP
Old 15th May 2006, 5:25 am
Guest
Posts: n/a
Default Re: Problem formatting
sidhu,
This may or may not help, but it will give some info on prob.
1 Go to my comp.
2 find drive ' Removable Disk' etc.
3 right click, go to properties
Is it Fat or Fat32 ?
what does windows report as available/ used space?
4 if fat32 reformat to fat(16)
5 go to tools
6 use windows error check
7 post results
Iridium
Old 15th May 2006, 7:58 am
Thank u for the replay
Its fat 16 and when i try to do a error check it says unable to complet the disk check
When i load some songs and then check after some time its showing some files like USB$..~ and iam unable to rename delete or cut them
I need to format my player to remove the files and with that files iam unable to play the mp3 files , so if i load the songs and play for one time iam getting those files so i tried to format it through MP3 coonvert tool but iam getting Rdisk utility eror
Plz
Old 15th May 2006, 11:21 am
try this:
Go to control panel/Administrative Tools/Computer Management/storage.
select disk managment.
right click on E drive. What is condition of drive? Healthy???? How much space???
Give all details, and all steps, and all results or I cannot help you.
select format. Post results
Alternatively you could do a format from command prompt, E.G. :
"E: format "
Alternatively, download this:
http://72.14.207.104/search?q=cache:...s&ct=clnk&cd=1
Post results
Iridium
Old 16th May 2006, 1:27 pm
Iridium
Have you tried that tool from HP?
Does it work ok in terms of formatting the drive of the player?
I would be interested to know..... I'm trying to find a tool that formats larger HDD players to just FAT16. Does that tool you recommend do it?
Old 16th May 2006, 1:57 pm
Guest
Posts: n/a
hi Binh,
Yep. In fact just last night.
I was testing new 2gb player's capacity (after all these posts re: fake chips) just to be sure mine was really 2gb. When I got to 1.6gb file size, I turned it off, then back on, and language had changed to chinese, and files were corrupted! Played for a couple of seconds, then "format error!"
message.
Windoze saw drive, but all data was corrupt. Could not format w/ Windoze, but this little tool did the trick, 1st try and w/ just 'quick format' option.
All files have been restored, and no probs. Go figure?! 1.7gb on drive now.
Highly recommended.
Iridium
Old 17th May 2006, 2:36 am
Originally Posted by Anonymous";p=&quot View Post
hi Binh,
message.
Highly recommended.
Iridium
Great sugestion.
I have added this tool in our Downloads area here - http://www.mympxplayer.com/dload.php...le&file_id=127.
An unusual problem with detection and formatting simon.crash Support and How To 9 31st May 2007 11:28 pm
Formatting SuePaterson Dead Players 13 24th Jan 2007 4:49 pm
Any way to fix the eBook formatting problem? michiganjfrog Support and How To 7 13th Jan 2007 3:29 pm
Problem after formatting! wizard83 Support and How To 11 22nd Oct 2006 2:06 am
2Gb now 1GB after formatting cbbreogan Support and How To 2 8th Jun 2006 10:14 pm
