Sound Equalization distortion
Old 19th Jun 2006, 11:21 pm
metalhead
May I offer a suggestion? Re-encode your mp3 files first using the exact EQ setting you like and then transfer the files to your player. I don't really trust the player to do a good job of adjusting the sound to my liking. You can also normalise the files (make the volume the same) too before transferring to your player.
I use dbPowerAmp which has a very simple to use interface and can process lots of files in different folders very quickly (http://www.dbpoweramp.com)
Old 20th Jun 2006, 1:17 pm
Hi NE1WeKnow, i didn't have this program...so thanks...it sure makes a difference!
I could hardly believe my eyes...well...my ears actually. What I thought to be good quality mp3s turned out to be rubbish when compared to the newer 'equalised' versions.
Thanks again.
Heavy metal is the beginning and the end ...
Old 25th Jun 2006, 7:13 pm
Glad I could help out...
No Sound rippedoff Dead Players 2 28th Aug 2007 4:04 am
Video Distortion mbrown174 Video related 7 27th Feb 2007 7:46 am
sound jtaiariol Support and How To 6 28th Nov 2006 6:33 pm
No Sound!! haseebanjum Support and How To 4 19th Sep 2006 6:33 pm
AMV sound antdroide Video related 2 11th Jun 2006 2:55 am
