battery
Old 16th May 2006, 8:39 pm
Guest
Posts: n/a
Default battery
My battery doesnt seem to be holding a charge anymore. I can charge it fine with my pc and the wall adapter and it shows it's fully charged because the little battery stops moving. But when I disconnect it I see the battery go down in a matter of seconds when theres something on the screen. I know im charging it right and I use the pause button for on and off, it also just started today. Should I try and see if I could buy a new battery or would FW do the trick because the battery isnt old. Please help.
Old 17th May 2006, 12:03 am
Default Re: battery
How long have you had your player now?
How often have you been charging it?
It's been recommended for the first 5 charges, to let the battery run down completely then do a full, overnight charge instead of doing little charges here and there.......
I haven't replaced a battery myself personally, so not entirely sure what's involved. A firmware update is not necessary, it will probably cause you MORE problems.
need new battery moneybankz Dead Players 0 20th May 2008 1:07 pm
ME2 Mp3 Mp4 Battery gloriaharvey Support and How To 4 6th Nov 2007 11:13 am
Take out battery KingGinola Support and How To 7 17th Feb 2007 9:27 am
battery katana General Discussion 5 24th Dec 2006 5:07 am
Battery Sua General Discussion 8 29th Nov 2006 7:21 pm
