Battery Level
I have this player it is a vl-545
The problem with it is that it has 9 battery level indicator but only 3 or 4 shows. It always display full, than after 3 hours or so it turns to half and then 20 minutes later it says low battery. I would like to fix this and if needbe i will post my firmware. |
Re: Battery Level
gman34
I have a player similar to yours. Mine does the same - only 4 actual images that repeats itself. I haven't check how many there are in the firmware file though.... I just took it that as is. |
Thanks Bud,
I am gonna try to see if i can reprogram it so it enables it but if I can't, oh well. |
| All times are GMT -7. The time now is 12:27 am. |
