[Solved] ASF Converter?
Old 30th May 2006, 4:46 am
Default [Solved] ASF Converter?
Hello.
Does anyone know of any ASF Converter? This is because my Mp4 Player cannot play .amv type video files. I need to convert it to .asf. Someone help me please? :cry: :cry: :cry:
Old 30th May 2006, 4:55 am
Default Re: ASF Converter?
Help is on the way, I will email you soon.
Old 30th May 2006, 4:58 am
Thanks alot
Old 30th May 2006, 5:45 am
Originally Posted by ketiakbusuk";p=&quot View Post
Hello.
I have just uploaded the ASF Convert Tool.
You can download it by going to the [Downloads] section, then choose [Tools].
Let me know if that works for your player.
Questions: Do you have the ORIGINAL sample video file that was on the player? If so, what is the file extension? Is it a .asf or .pta or something else?
Old 30th May 2006, 6:40 am
Hello.
Nope. There isn't any sample video when I bought it. But, when I try to do video recording, (needs to be connected to camera) the file (recorded video file) will appear as a .asf file.
Old 30th May 2006, 7:15 am
Oh and one more thing. I forgot to say thank you ^_^
[solved] MTV Converter? septi Video related 5 11th Feb 2007 4:24 am
SOLVED - HELP!!! just downloaded amv converter.............. Peyton Manning Support and How To 3 8th Sep 2006 8:05 pm
[solved] STILL CONVERTER PROBLEMS!!!! PHIL Video related 3 13th Jul 2006 9:47 am
[solved] Problems with MTV Converter lightzout Support and How To 13 4th Jun 2006 12:47 pm
[solved] amv converter not converting Video related 4 29th Apr 2006 1:02 pm
