Re: Problems with MTV Converter
Thanx Iridium...and thanx to tadad1...i installed the codec pack that tadad1 told me about..and unistalled and reinstalled the converter and it works..although its converting slow..its still converting...I think you have to install the codec in order for the converters to work. Thanx
lightzout
Yes, with no codec install, the .MTV converter doesn't know how to 'decode' your .avi file. |
Re: [solved] Problems with MTV Converter
Thanx Admin for recomfirming it.
Wow! that was a quick fix.
I'm glad to be a part of a forum with such great talent and quick responses. Keeps it lively! lightzout- Could you edit original post and put solved in the title? Thx... |
| All times are GMT -7. The time now is 11:43 am. |
