[solved] Problems with MTV Converter
Old 4th Jun 2006, 12:35 pm
Default Re: Problems with MTV Converter
Thanx Iridium...and thanx to tadad1...i installed the codec pack that tadad1 told me about..and unistalled and reinstalled the converter and it works..although its converting slow..its still converting...I think you have to install the codec in order for the converters to work. Thanx
Old 4th Jun 2006, 12:38 pm
lightzout
Yes, with no codec install, the .MTV converter doesn't know how to 'decode' your .avi file.
Old 4th Jun 2006, 12:41 pm
Default Re: [solved] Problems with MTV Converter
Thanx Admin for recomfirming it.
Old 4th Jun 2006, 12:47 pm
Wow! that was a quick fix.
I'm glad to be a part of a forum with such great talent and quick responses.
Keeps it lively!
lightzout- Could you edit original post and put solved in the title?
Thx...
Problems with amv-converter and player Meinolf2 Video related 3 30th Sep 2007 3:54 am
AVI Converter problems Buzzygirl Video related 13 26th Sep 2007 5:47 pm
avi converter problems for rockchip player gmaster Video related 2 7th Jan 2007 1:09 pm
AMV Converter 4.03 problems avvalex Video related 1 19th Jul 2006 3:46 am
[solved] STILL CONVERTER PROBLEMS!!!! PHIL Video related 3 13th Jul 2006 9:47 am
