[solved] Converting AVI to AMV using de AMV convert tools
Old 13th Jun 2006, 1:15 am
Default [solved] Converting AVI to AMV using de AMV convert tools
hi all, i m new here...
although i can play the video file on my media player and the converter... the status changed to error when i click convert... wad can i do? do i nid another codec for tis? or simply juz use another convertER?
plss help me wif this problems
Old 13th Jun 2006, 1:22 am
probamaticmp4, Great user name, I would say you still need some codecs. I just installed the K-Lite Mega Pack which is the most extensive codec pack I have seen. You can download it here:
http://www.codecguide.com/download_mega.htm
Hope this helps
[solved] *.avi converting ... doom Video related 5 18th Jan 2007 10:36 am
[SOLVED] AMV Convert Tool doesn't convert avionik99 Support and How To 2 20th Nov 2006 9:30 am
where can i get the source code for AMV Convert Tools crazygazza General Discussion 0 31st Oct 2006 1:14 am
[solved] Converting video CD to AMV Loc Video related 5 27th May 2006 7:22 am
[solved] Installing the Conversion Tools steffan Support and How To 4 29th Mar 2006 12:15 am
