earphone problem
Old 19th Jun 2006, 3:33 pm
the_game
Guest
Posts: n/a
Default earphone problem
Hi,I bought a mp4 player 2 weeks ago but I'm having some probs with my earphones.I hear the music but very low even if I but the volume at max.I unplug it and plug it again and sometime the music comes back loud but most of the time it stays low.Just wanted to know if there is a reason to the prob or should I buy a new one.And if a buy a new one,wich kind of good earphone should I buy? I have the nano clone mp4 player.
ps:also wanted to know if the earphones that comes with the nano clone mp4 players are the same then the nano ipod player,THANKS!
Old 19th Jun 2006, 4:25 pm
the_game
In most cases the earphone that come with the player are poor quality, it is a good idea to buy some new ones. If you have trouble finding a pair with 2.5mm plug try looking at mobile phone accessories I have heard Sagen phones use the same headphone socket and Nokia have a 2.5mm to 3.5mm converter that will let you use regular 3.5mm headphones.
earphone jacks Camaro General Discussion - Uxcell.com 3 20th Feb 2007 8:53 pm
Is it possible to listen radio without the earphone? Lejigabou Support and How To 3 11th Nov 2006 4:41 pm
Earphone Adaptors 2.5mm to 3.5mm jay Miscellaneous 6 19th Sep 2006 7:39 pm
Earphone question Donkez Miscellaneous 11 8th Aug 2006 11:45 am
Earphone question the_game969 General Discussion 6 26th Jul 2006 7:19 pm
