replacement battery
Old 27th Jun 2006, 12:12 pm
masfud
Guest
Posts: n/a
Default replacement battery
I need a replacement battery for my 1.5 inch generic mp4 player anyone know where to get one or any other battery that will fit
I need a replacement battery for my player does anyone know where to get one my player is the same as this one -http://www.mympxplayer.com/album_showpage.php?pic_id=62
Old 27th Jun 2006, 1:11 pm
Hi masfud
What type of player do you have?
Battery sizes will be different depending on the player.
Old 27th Jun 2006, 3:28 pm
masfud, Using s1fwx extract your firmware then run the list.bat and a command window will open listing your firmwares attributes and the files contained within. You should find an entry near the top that specifies your battery type and voltage.
Speaker Replacement? ALP1987 Support and How To 4 9th Jan 2009 9:58 pm
Battery Replacement? ALP1987 Support and How To 4 23rd Oct 2008 4:31 pm
where to buy replacement battery? barnbug1 Support and How To 1 1st Jan 2008 12:06 am
Nano battery replacement yngwie0001 Mods and Themes 1 18th Jan 2007 8:53 pm
Battery Replacement yngwie0001 Mods and Themes 3 16th Jan 2007 12:30 pm
