-   -   [Solved] Correct Battery rating (http://mympx.org/forum/support-how/33472-solved-correct-battery-rating.html)
prasanna 29th Jun 2006 5:07 am
Hi Tadad1,
When i look at the battery of my player it has written as 3.7V.But when I check using list.bat it says 1.5V alkaline.
which one is correct?
regards,
prasanna
tadad1 29th Jun 2006 7:07 am
prasanna, I would suggest you would have to go with what is written on your battery. Is the firmware you are using the original?
I know you can change your battery type with Firmware Modify http://www.mympxplayer.com/dload.php...ile&file_id=17
prasanna 29th Jun 2006 9:50 pm
Re: Correct Battery rating
Hi Tadad1,Thanks for that.Anyhow right now i dont want to play with my player as it id working perfectly.
prasanna
