Firmware need for my mp4 player
Old 3rd Jul 2006, 3:07 am
Default Firmware need for my mp4 player
Hi all,
I just brought my mp4 player last month and I'm just new to mp4 player. I was tried to upgrade the firmware for my mp4 player because I wanted to change the theme of my player by simply download the firmware and upgrade it.
The message showed successfully upgraded, then I restart my mp4 player. Unfortunately, I'm not able to start my mp4 player again. After I read through the forum, I think I had upgraded with a wrong version of firmware. I had backup my firmware using the S1fwx. But I think that is not the full firmware.
I followed the reference of "Recovery dead player" in the forum and I successfully make my player detected as "ADFU Device" in Windows XP. Then I tried to upgrade the firmware using the "MP3 Player Upgrade Tool". I had tried several version of firmware that download from the internet, but the process of upgrading just hang in the half way. It hang at the "Downloading the restorable main program".
Does anyone know the firmware of my player ? How to make my player work again ? Please help me !!!!
My Mp4 player is showed in the URL below :
http://www.xundu.com/english/product...type=5&pid=922
(Sorry, I don't know how to upload the picture.)
Old 3rd Jul 2006, 3:39 am
Default Re: Firmware need for my mp4 player
kenseowhp , the website that you provided to show your player has a download section that has full firmware. I suggest you try the XD-600 and then your backup.
Old 3rd Jul 2006, 6:22 am
Thanks a lots, tadad1.. I had downloaded the firmware and upgraded it.. but, the process still hang at the "Downloading the restorable main program".
Old 3rd Jul 2006, 6:23 am
I have another same model mp4 player with mine.. Is there anyway to copy out the firmware from that player ?
Old 3rd Jul 2006, 6:35 am
kenseowhp, Yes you can use s1fwx to copy the firmware from the other player. Download the program HERE
Instructions on how to extract the firmware are HERE
