USB Car Charger for Nano-Clone - a Curious Issue
Old 5th Jul 2006, 6:01 am
Default USB Car Charger for Nano-Clone - a Curious Issue
Hi,
I bought a "Car Charger/FM Transmitter" for my 1 GB Nano-Clone as below:-
The odd thing is that it seems not to be able to charge the battery even though there is 5V as measured at the USB connecting lead.
Using the same USB lead that came with the player, it charges just fine via USB port on a laptop (even if the laptop is powered off).
The main evidence of charging is the battery indicator on the LCD display so my question is why no such charging indication when the 5V is presented from the car charger.
Any comments would be much appreciated.
Cheers from Mike
Old 5th Jul 2006, 6:22 am
Default Re: USB Car Charger for Nano-Clone - a Curious Issue
its hard to say. I just got a unit a few days ago, and I cant even get mine to charge. I think its a matter of crappy quality. If I could do it over I dont think I would of even got a nano clone...grrrrr.
I would think it would charge for you, but then again its hard to tell. Mine will only charge a little if I plug the unit in the wall with the unit switched to off. Otherwise it does nothing.
Goodluck.
Old 6th Jul 2006, 3:29 am
Just as a followup, I fully discharged the player battery and tried the car charger and found the player to be charging OK. So it seems to be just a case of charging without any indication on the LCD unlike when charging via a Laptop PC.
Cheers from Mike
Old 6th Jul 2006, 3:50 am
msun, Interesting, what happens when you plug the charger in, does it go to the connection screen then back to menu?
Old 6th Jul 2006, 3:59 am
Tadad1, No, it does not go to the connection screen and then back to the menu; it just stays "as is". That aspect is actually more convenient I guess.
The behaviour must be someting to do with whether the data lines on the USB port is held high or low or something similar. When connecting to the laptop, the connection screen DOES display even when the laptop is powered off.
Cheers from Mike
Old 6th Jul 2006, 4:08 am
msun, the reason i ask is that my daughter has an iPod shuffle which has a natty little USB attachment that you can put 2 AAA batteries in and it will charge her ipod. I tried it on my nano clone and when connected it went to the connection screen then back to menu and I thought it just was not working. I would be great if you could recharge from a couple of AAA batteries if you were out and about.
New 4Gen nano clone with Dock connecter, well that's a clone Hit General Discussion 5 18th Jan 2009 4:04 pm
Onda clone video playback issue nikione Support and How To 1 29th Sep 2008 1:33 pm
Would a 3.7 V mAH Ipod Nano battery work in my nano clone? speedypear Support and How To 8 6th Mar 2007 8:32 pm
UK charger for nano clone goldenballs General Discussion 4 8th Aug 2006 11:56 am
Just got my mp3 nano clone- battery issue? Rocker81 Support and How To 10 10th Jul 2006 5:45 am
