Help me choose Battery for my China Pod
Ok,
I want to upgrade my player with an new Battery since the standard battery life ain't enough for my needs. Curretly: Videoplay Aprox: 120 Minutes Mp3-Play with sleepmode Aprox: 240 minutes Now I red the Firmware of the Player with Firmware Modify after Extraction and it says there: 3,6V Li-Polymer-Battery Now I've seen an Ipod compatible Battery with 2200 mAh on Ebay this one for example: http://cgi.ebay.com/BATTERY-for-IPOD...ayphotohosting Will it work on my China Pod ? :) Thank You very much |
| All times are GMT -7. The time now is 9:11 pm. |
