FM Transmissor - Pitch Noise Problem
Old 18th Jul 2006, 10:42 am
Default FM Transmissor - Pitch Noise Problem
Hello everyone,
I bought a FM Transmissor and Iīm facing a problem that I believe is happening to another users from this forum.
When I set the frequency that the transmissor will use to transmit the FM radio wave and hit the "ON" button, any radio that play the same frequency near me will listen to my songs....BUT...I can hear a disturbing NOISE, like a pitch noise, pi......pi........pi.........pi.........pi........ ..pi........pi.......pi, that I donīt know why itīs happening.
I have searched many forums and I saw something related to a "noise filter", that this kind of "FM Transmissor Wireless" donīt have. Maybe one of you that saw or read something about it or Know how to fix it can help me and other people with the same issue.
Please, any suggestion will be valid.
Thank you in advance
guivarrichio.
Old 19th Jul 2006, 4:22 am
guivarrichio
What FM range is your transmitter transmitting in?
I have one that is transmitting in the 88.x range and it works fine on my car stereo. There is an occassional 'static' noise, but as I keep driving, it goes away, so I think it's depends on the LOCATION.
Have you tried the other ranges available on the transmitter?
Old 19th Jul 2006, 5:13 am
Default Re: FM Transmissor - Pitch Noise Problem
Hello Binh, Yes I have tried a lot of ranges....
My transmitter works in any range I set it to work...but I will try once more in the range 88.x.
If I record the pitch noise, would you like to listen to it?
Thank you
Best regards friend
Old 19th Jul 2006, 6:06 am
Hello Again, I just tested and it is transmitting the stupi* pitch noise....damn
The range 88.x and all I tested donīt work ok.
pi pi pi pi pi noise is making me crazy, it happens with more frequency when a bass sound, a strong sound plays....
Here is some descriptions
Wireless FM Trasnmitter
Model No: 668A
Working current: 38mA
1.5V x 2AAA Size Battery
Please check this Photo Link
Thanks in advance.
Old 22nd Jul 2006, 4:48 am
guivarrichio
I don't have the same FM transmitter as you do. Mine has a cradle so I can sit my MPx in it and it plugs straight into the lighter plug.
Mine also only has 4 preset ranges.
Quick question, you have tried turned up the VOLUME on your player to FULL then compensate it by turning down the stereo volume alittle? Maybe that might 'lighten' the pitch noise?
Otherwise I would suggest try to get a hold of another one as yours might be faulty.
Actually, try it in ANOTHER car if you can see what happens?
Noise Problem Psyfurius Support and How To 7 10th Jan 2009 7:35 am
Static buzzing noise that never goes away eello123 Support and How To 5 4th Sep 2007 9:07 pm
MP4 Background Noise Darklink Support and How To 5 31st Aug 2007 10:36 pm
Noise with new mp3 player karletto66 General Discussion 4 27th Oct 2006 10:57 pm
BZZZ noise Ruggenet General Discussion 7 17th Sep 2006 1:56 am
