Some problems Help?
Old 28th Jul 2006, 12:16 am
Guest
Posts: n/a
Default Some problems Help?
I bought a mp4 player about two weeks ago.
It has two small speakers on it. Actually it looks like
It's trend is Piranha Mp4 Player in my country,and Model is "Cloud"
It has SC85052C with Act_V3.5.35.. firmware
Here my questions..
1-I do not choode the mp3 folder that I want to listen. I always return back to root directory. Then I have to say next next to the other folder. It is disgusting.
2-Can I watch my AMV videos on fullscreen.. I tried lots of thing but I could not do that.
3-Is there any newer version of my firmware?
4-Is there any way to make the menu more faster?
Thanks you..
Old 28th Jul 2006, 12:18 am
Default Re: Some problems Help?
I wrote this topic in guest mode )
Old 28th Jul 2006, 12:36 am
SnigRO,
When selecting folders try setting Repeat to Normal and select the folder by pressing play. This helps on most players.
For full screen video what size is your screen 1.5 or 1.8?
Trying to upgrade your firmware is not recommended as you could end up killing your player completely.
If you have not done it yet I suggest you backup your firmware using s1fwx which you can download HERE and a guide on how to do this is HERE
If you have any problems with your player in the future the backup can be very helpful.
If you get a chance it would be great if you could upload your firmware to site by using the upload button at the top of the page HERE
I know there are a few members looking for firmware for your type of player so it would be a great help to them.
Let me know what size your LCD screen is and I will help you with the fullscreen video.
Old 28th Jul 2006, 1:07 am
my screen is 1.5
Old 28th Jul 2006, 1:13 am
tadad1,
you said that : When selecting folders try setting Repeat to Normal
I coulnd not do this.. Can you explain breifley please..
I'II TRY TO BACKUP MY FİRMWARE THEN UPLOAD TO THE WEBSITE OK..
Old 28th Jul 2006, 1:14 am
SnigRO, If you want full screen 1.5 then you need to set size to 128x128. I suggest you use Amv Player Utilities 4.03 HERE
After you install it you need to go to the AMV Converter folder and open the AmvTransform.ini in notepad and edit to CHIPTYPE=0 then save, this will unlock the settings for 1.5 screens.
If you find you are getting Format Error warnings when you play your AMV on your player then lower the frame rate in the AMV Converter settings.
Cheers
Old 28th Jul 2006, 1:17 am
I made the "When selecting folders try setting Repeat to Normal " setting
Thank you, This helped me..
One more question..
Do I have to use the menu slowly ?
Old 28th Jul 2006, 1:32 am
SnigRO, There is not a lot you can do about the slow menu I'm sorry. It is one of the annoying things about the players although some players seem to be a little faster than others.
Old 28th Jul 2006, 1:58 am
I upload the firmware to where you told me..
Now, I am trying to make the video fullscreen..
thanks
Old 28th Jul 2006, 2:17 am
thank you for everything.
Now I can watch it in fullscreen mode but the program made the movie a little bad screen resolution.. Is there any way to fix it?
Problems with new mp4 al pal Support and How To 4 5th Nov 2007 5:03 am
MP4 Problems mark2 Dead Players 18 2nd Feb 2007 11:01 pm
problems with vl-547 dp Support and How To 2 25th Sep 2006 10:47 pm
PTA. Has to much problems PTA Video related 5 19th Jul 2006 7:25 am
AMV 4.00 problems max2 Video related 10 1st Jul 2006 2:59 am
