convert DVD problem using 4.03
Old 1st Aug 2006, 11:46 pm
Default convert DVD problem using 4.03
This is my first player, so I am having trouble to convert the movie. Please help.
I try to convert a DVD which contain 4 VOB files, and I am using MP# Player Utilities 4.03. The program only convert part sence from each file. Let's say the VOB should contain 1 hour, the program only convert the first 12 mins.
Am I missing something?
By the way, the Utilities 3.68 contains virus, does anyone has a clean one?
Thanks in advance.
Vincent
Old 2nd Aug 2006, 2:14 am
Default Re: convert DVD problem using 4.03
Hi Vincent, I also had problem when converting the VOB files directly using AMV converter instead i found a work around.
First u convert the VOB files into avi files.Then try converting those avi files using AMV converter tool it will work.
For ripping the DVD u can use DVD decryptor.It will rip the DVD files onto ur hard disk then use softwares like PocketDivxencoder to convert them to avi.
Make sure u have installed all the necessary codes beforehand.U can install K-lite mega codec pack.
Hope this helps.
prasanna
Old 2nd Aug 2006, 4:24 am
Hi Vincent !
I am successful in converting vob files to AMV files with the following:
Convert vob files > avi using Xmpeg software
Convert avi files > amv files using AMV Converter Version 4.00 with K-Lite Mega Codec installed.
Give a try !
Regards
jasstone
Problem trying to convert DVD to AMV eee Video related 1 26th Dec 2007 1:01 am
AMV Convert problem [Solved] amadeus Support and How To 3 14th Sep 2006 11:37 pm
Convert a dvd problem vcllvc Video related 2 14th Sep 2006 3:46 am
[solved] Problem with AMV convertor - can't convert files Tina Video related 5 1st Jul 2006 9:09 am
AMV Convert will not convert files, crashes Kosh Video related 5 13th Jun 2006 9:00 am
