Problems with Mp3 Player Utilities 3.68
Old 5th Aug 2006, 10:05 am
Default Problems with Mp3 Player Utilities 3.68
I have installed Mp3 Player Utilities 3.68, but the AMV converter will not run. I click on it, and the hourglass symbol flashes for a second then disappears. There is no error message. I am running XP SP2. Any suggestions?
Old 5th Aug 2006, 2:02 pm
elDiablo
Try uninstalling it.
Then create a new user account with admin rights. Log in as that NEW user, then install it (make sure you put the tick for "all everyone to use").
After that install, log back in as yourself and see if it runs now.
Every so often, the Convert Tool doesn't open properly on some machines.
Try that and let me know.
Old 8th Aug 2006, 5:46 am
Default Re: Problems with Mp3 Player Utilities 3.68
Tryed what you suggested, but the same thing happens. Could it be a software conflict?
Old 8th Aug 2006, 7:03 am
elDiablo, have you tried other versions of the utilities?
If you have a 1.5 lcd versions 4.00 and 4.03 will do the same as 3.68. For 1.8 LCD versions 4.00 or 3.57.
MP3 Player Utilities Problems welshbhoy Support and How To 0 26th Jan 2008 12:35 pm
Problems with MP3 Player Utilities 3.57, 3.68 & 4.0 miffedmom Video related 18 24th Apr 2007 7:40 am
MP3 Player Utilities 3.11, 3.8 or 4.11 Nonie Support and How To 2 9th Apr 2007 12:03 am
Problems installing/uninstalling Mp3 Utilities 4.03 omega1 Support and How To 6 26th Dec 2006 4:12 pm
MP3 Player Utilities 4.05 veggen Video related 4 21st Sep 2006 3:28 am
