[Help] Player keep's re-booting itself.
Old 8th Aug 2006, 4:50 pm
Default [Help] Player keep's re-booting itself.
Hi there. I have a little problem with my NanoClone (which is a 256 MB version).
Full Specs:
FIRMWARE VERSION ---- PMA300_006
2005/11/04
RYJ-3.5.35
2005/12/16
So here's the deal... About two months ago, I uploaded to the player a new firmware file... Everything seemed normal, until I noticed that the player tended to re-boot itself when I switched between Video player and MP3 Player.
Then, I started to have problems with the earphone entrance... Sometimes both sides work (Left and Right), sometimes only Right.
And now, it reboots itself everytime I try to swich song or select everything with the "Fast Forward" key...
So guys, is there anything I can do to fix it?? BTY, I re-uploaded the original firmware that came with this troublesome machine....
Old 8th Aug 2006, 5:09 pm
Zephir, if you are still having problems with the original firmware try formating the player (not quick format) or running an error check with bot options selected by right clicking on the player in explorer and choosing Properties>Tools.
Old 8th Aug 2006, 5:37 pm
Default Re: [Help] Player keep's re-booting itself.
Ok, and then what should I do??
Theres nothing better than a night of videogaming with your friends 8)
Old 8th Aug 2006, 7:02 pm
Zephir, Once you have formatted or checked for errors or both try loading some files back to your player and see if the problem still exists. If you find you are still having problems then there may be a short in your control buttons due to moisture or dirt build up you could try dismanteling and cleaning.
player not booting abb Dead Players 1 4th May 2006 1:21 am
