-   -   FM radio problem (http://mympx.org/forum/support-how/34079-fm-radio-problem.html)
flik 2nd Sep 2006 2:56 am
FM radio problem
Hi! I have bought United MP-7518 MP4 player, it is a nano clone. I have a problem with FM radio function.Sometimes, while fm radio plays normally, when I change FM stations that I have saved, it seems like there is no signal in any station. I shutdown and open it again and sometimes works, sometimes not.What can I do?
Sorry for my English...
Here is my mp4 player:
http://img145.imageshack.us/img145/7...6038ce9.th.jpg
admin 2nd Sep 2006 3:09 am
flik
I haven't seen this problem before with any of my players.
However, from what you've told me, if it 'sometimes' works and sometimes doesn't, then it seems to be either a faulty FM transmitter in your player or in your earphones.
The quickest way to test is to try a different set of earphones or get yourself a good set of earphones. Some of them have an FM transmitter in the earphones, so it might make things better.
Otherwise most likely it seems like a faulty FM transmitter chip inside your player then.
How long have you had it and can you claim warranty for it?
flik 2nd Sep 2006 4:47 am
Re: FM radio problem
thanks for your quick reply. I am going to test it with my friend's earphones.If it works, I'll buy another set.Otherwise, i will try to communicate with FUNAI.I have an one year warranty, and i have bought my mp4 player 2 months ago
