-   -   low battery in my 2 gb mp4 player (http://mympx.org/forum/support-how/34091-low-battery-my-2-gb-mp4-player.html)
torn22 2nd Sep 2006 12:55 pm
I have the player about 24 houres,
I fully rechrege and discherge the player two times!
and the battery is very weak, about 3 houres until it shut down!
when it show that the battery is full, after 5 mintues the icon drop one
level.
what can I do with this?
maybe the battery is bad? or 3 houres of playing is normal?
tadad1 3rd Sep 2006 9:54 am
torn22, How long are you charging your player for? Give it 4-5 hours and see if it makes a difference. If the LCD is on all the time it can drain the battery quickly, go to Settings\LCD Set\Darkle, dark or Black (Depending on your player) and set the slider to 15 -30 seconds, then your screen will turn off when playing music. The battery sizes vary between players but you should expect between 5 -8 hrs continuous music play with power saving on and 3- 4 hours Video play.
torn22 7th Sep 2006 8:44 am
Re: low battery in my 2 gb mp4 player
Ok thank's,
but now i have a big question.
does anyone open the "ipod clone case"?
I want to know this becuse I open mine to check the battery mah.
and my battery mph is seem to be 250 mah.
that look's very week power, compared to my phone.
so what is the power of your battery?!?!
that's very importent to me, thank's.
tadad1 7th Sep 2006 3:15 pm
torn22, Most players are around 200 - 250 mAh but I have seen some 340 and 400 mAh but generally there is not enough space for a battery of this size.
