Sumvision OpusPro 1GB problems
Old 12th Sep 2006, 5:42 am
Default Sumvision OpusPro 1GB problems
Hi guys,
I am new here, and wondered if anyone could help?
Firstly Firmware for my Sumvision Opus pro 1GB is V3.5.35 and I cannot get the damn thing to access folders in Music mode, I get to local folders, select a folder yet when it goes back to play mode, it does not play files from that folder..... so when you have for example 300 songs on the player and you want to play the last few, you have to scroll through 200 odd tracks before you get to the ones you want!
Secondly can i use S1FWX on this model, as i have tried to use this on windows 98se, and it says it does not detect any devices, despite windows showing it on the desktop as drive G.
Any help would be appreciated.
Cheers
Old 12th Sep 2006, 6:06 am
coline1,
When you go to Local Folders press the Menu button then scroll to the folder you want then press the play button not the menu button which will take you back to the music player with that folder loaded.
The other thing you may need to do is press the menu button while music is playing and make sure Repeat is set to Normal.
s1fwx will only run on Win 2000 and up. There are no tools for extracting your firmware for 98.
Need fw for KPAC (Sumvision) MP4 4GB mpx-boj Firmware 2 13th Sep 2009 3:30 pm
Sumvision Opus III brianh88 General Discussion 2 17th Jan 2009 12:58 am
Sumvision Gio - Firmware Kickback Support and How To 1 3rd Aug 2007 7:33 pm
Help with Sumvision KPac seanamos Video related 11 31st May 2007 11:31 am
Sumvision Opuspro 2gb ipod nano clone 1.5 screen trinitale Dead Players 0 6th Aug 2006 8:01 am
