audio problem
Old 13th Sep 2006, 10:37 pm
Default audio problem
my nanoclone player has an audio problem especially when u push the next button, the voice of the artist suddenly turns low and background music suddenly turns up, is this the problem of my headset or the player, tnx
Old 13th Sep 2006, 11:55 pm
Default Re: audio problem
You could try using a different set of earphones, check if the same problem still persists. If the problem occurs from minimum all the way to maximum volume for every single volume setting, there are 2 possibilities:
1) the player's earphone jack has a loose/broken connect.
2) the Action ATJ processor chip has a problem, it has a built in DSP processor and is might what have caused your problem.
I've faced this problem before but it was a matter of a broken connection at the earphone jack to the mainboard, a little soldering fixed it.
MP4 player no audio problem Salewarehouse Video related 1 7th Dec 2009 2:06 am
Video/Audio Synch Problem LG FM37 Aussieadam Video related 0 5th Oct 2008 8:27 pm
Problem with MP2-Audio-codec: no sound (viDrop.55) lca77 Video related 1 20th Jul 2008 2:28 am
[solved] Audio/video syncrhonization problem with Onda VX858 Matteo Video related 2 26th Mar 2008 11:13 am
1.8 Video Problem: Audio is too fast nabilash Video related 0 3rd Sep 2006 1:19 pm
