2 Problems with E-Bay MP4 Player
Old 14th Sep 2006, 4:57 pm
Default 2 Problems with E-Bay MP4 Player
hello,
my english isnŽt the best but iŽll try it
iŽve got two problems with a player like this one:
http://www.mympxplayer.org/album_showpage.php?pic_id=62
1. i cant choise the menu FM to hear radio. when i try to get in the fm menu it jumps over to the next menu point. what should i do ?
2. the player isnŽt able to read the names of the folders. for example iŽve upped a folder called "Madsen" with the track "die perfektion" the player showes only "M D" in the display. the first letter of the folder and the first one of the track. is that normaly ?
thanks a lot so far !
Old 14th Sep 2006, 6:44 pm
mp4ebayplayer, Your player may not have the function and no radio chip or if it has the chip may be faulty. You should contact your seller and check.
I am not sure about the naming problem, I have one player that will only show the old dos shortname like the forlder Underwater Sunlight will become UNDERW~1 but I would say it is not normal to get just the first letter displayed.
Old 14th Sep 2006, 11:43 pm
Default Re: 2 Problems with E-Bay MP4 Player
ok thank you for your answer,
iŽll write him an e-mail now
Old 16th Sep 2006, 4:42 am
I know the problem with the players from ebay-sellers like etop, ylanx and whatever.
These are the low-budget versions of the nano clones. They have FW 3.5.35 and some features disabled, like FM, Tel.book and often have only one or two games. You cant re-enable things like the FM on them, because there are hardware parts missing...
P.S.: I'm going to sell my white 2gb nano clone soon. It has FW 3.5.37 with File Browsing, FM, Tel.book and four games.
I'm from germany (düsseldorf). So if you want to buy it, then tell me before i put it on ebay.
It ist as good as new.
Send me a PM if you are interested.
16 gb 2,8 mp4 player, problems? bugger Support and How To 0 22nd Oct 2009 11:02 am
My player has problems help?? tes2131 General Discussion 1 22nd May 2009 12:23 am
problems with player in mac osx krebsi83 Support and How To 1 27th Aug 2008 2:39 am
Many problems with new player.... Marix Video related 2 17th Sep 2007 4:22 am
problems with my mp3/mp4 player ... Ghost Support and How To 1 10th Oct 2006 1:25 pm
