battery duration (Ipod look-a-likes)
Old 15th Sep 2006, 2:21 pm
Default battery duration (Ipod look-a-likes)
Hello,
I would like to know if someone has this Ipod look-a-likes MP3 player or has a similar version.
The battery duration is about 2 hours, not more. Is it possible ? I think it is very low; I didn't expected myself to do a week with a battery charge, but I hoped it could last 6-7 hours, a normal time for this kind of battery. Do you think updating firmware could change something ? My installed firmware is v35.37 dated 2006-06-23.
Thanks for your reply.
Old 17th Sep 2006, 1:30 am
Default Re: battery duration (Ipod look-a-likes)
The manufacturer's battery are not that lasting as it seems. My 260mAh "Li-ion", at least that's what the battery cover claims, only lasts about 3 or 4hrs max.
And it gets totally drained flat from a full charge in about 1.5days without even turning it on.
Not sure if the change in firmware would improve the battery life, but so far seems like no one here has suceeded in improving the battery life with a firmware change.
Upgrading chipod with ipod battery Yellow Rat Mods and Themes 1 14th May 2009 12:53 am
MP4 8GB ipod clone battery acting strange yessirsir Support and How To 0 21st Feb 2009 10:41 pm
how can i change battery from a ipod clone? Ecege Support and How To 0 6th Jul 2007 6:16 pm
iPod Nano Clone Battery Life aurelio General Discussion 5 30th Mar 2007 5:34 pm
Nano Clone ipod 1GB -- battery change jasstone General Discussion 3 13th Jul 2006 5:53 am
