how do i charge the battery
Old 18th Sep 2006, 4:23 pm
Default how do i charge the battery
Hi, i just got a 2gb mp4 nano-lookalike a few days ago. This is probably a dumb question but...how do i charge the battery? I know you connect it to the computer but does it have to be on?I need step by step instructions please. I did it once before but i think it was just luck the way i did it cause i dont remember how i did it.
Old 18th Sep 2006, 5:59 pm
peruvianfreak250, When you plug your player into the USB port it the player should show a USB connection screen and the battery will start to charge. The player must be turned on to charge. While the player is charging it should show an animated battery icon. The player may take up to 4 - 5 hours to charge fully.
Unibit X-320 Player - How do I charge battery? TyphoonTycoon Support and How To 1 24th Nov 2007 8:50 pm
best way to charge battery Aiu Support and How To 3 11th Jan 2007 6:20 pm
18 Hours Continuous Music Play on a Single Battery Charge. tadad1 General Discussion 0 17th Nov 2006 7:40 pm
Battery Charge Problem? General Discussion 32 31st Jul 2006 9:47 pm
