[Help]error with amv converter again
Old 21st Sep 2006, 3:19 am
Default [Help]error with amv converter again
can anyone can help me?
when i convert avi file at least 500mb, or around that size.
my application(Amv converter 4.0) says error. and closed.
but if i convert only 50mb(small size), its work.
i want to convert DVD from .VOB, also error.
what happen?
thx for all
Old 21st Sep 2006, 3:49 am
yephta, You may need some decoder componenets, try installing the K-Lite Mega Codec Pack on your PC
http://www.free-codecs.com/download_...hp?d=2267&s=42
Old 21st Sep 2006, 6:46 am
i've install k-lite mega code pack...
but the application close.
Old 22nd Sep 2006, 1:46 am
thx for tadad1...
after i install my windows again.
it solved the problem. thx for share the codec
[HOWTO] Remove DISK ERROR! / Error format etc.. on AK2025 Errorboy Support and How To 16 30th Jan 2010 3:28 pm
3.68 amv converter error when converting mandamoses Video related 6 16th Dec 2007 8:05 am
AMV Converter ERROR Snakebite Video related 7 25th Jul 2007 10:32 am
amv converter - getting status error freelander Video related 5 27th Oct 2006 6:28 am
[solved] Error converting using MTV Converter Whiper Support and How To 7 4th Apr 2006 1:11 am
