need help for firmware
Old 26th Sep 2006, 7:26 pm
Default Re: need help for firmware
Originally Posted by capa57";p=&quot View Post
yes but where i can found the good firmware , i'm lost i need help ...
capa57, there really isin't any straightforward solution to the correct or good firmware. No one really knows which firmware is compatible with which player, it's all a matter of trial & error, and a little luck.
You just need to keep trying until you get the right firmware.
Old 27th Sep 2006, 10:09 pm
yes but i don't found it ...
nobody gets this firmware please ????
Old 27th Sep 2006, 10:32 pm
capa57, try to email your seller and ask if he will send you a copy of the firmware.
