converting amv has become problem
Old 23rd Sep 2006, 7:16 pm
Default converting amv has become problem
when i convert video files to amv the picture is lost at the sides please
help me
Old 23rd Sep 2006, 9:05 pm
Default Re: converting amv has become problem
gnanesh, you will need to ensure that the conversion resolution is set to the correct display resolution of your player. There is a step-by-step guide here: http://www.mympxplayer.org/viewtopic.php?t=32
Also, you might want to pre-process your videos before you convert to AMV format, there is a guide by tadad1 here: http://www.mympxplayer.org/viewtopic.php?t=805
Old 24th Sep 2006, 8:01 am
gnanesh, What size is your screen and what size are you converting to?
Converting DVD to *.smv ILLIBRIUM Video related 0 30th Dec 2006 7:24 am
Problem converting AMV to 160x128 resolution! MusicBOY Video related 27 29th Dec 2006 6:48 am
converting problem abisi1 Video related 1 8th Nov 2006 10:33 am
Converting the avi to amv Video related 9 12th Jun 2006 6:58 am
[solved] Problem converting music files Lp_Lauj Support and How To 11 5th Jun 2006 10:21 am
