E-Book Problem
Old 24th Sep 2006, 5:23 pm
Default E-Book Problem
Hello, I have one of this:
[web:8ccc8e471a]http://mympxplayer.org/nexxtech-1-asp108.html[/web:8ccc8e471a]
The player works propertly but...
I have a problem using E-Book function:
First two lines of every "page" are showing up with no separation.
Every 3 pages last line doesn't show, so I lost one line of text aprox.
How shall I do to fix that?
Shall I do a firmware upgrade?
Gonzalo
PD: Sorry my bad english, I am Argentinian
Hola, tengo uno de estos:
El reproductor funciona perfectamente pero ...
Tengo un problema usando la funcion "E-book"
En cada una de las páginas, las primeras dos lineas se muestran juntas.
Cada tres páginas, no aparece el ultimo renglon, por lo que pierdo una linea y no entiendo parte del texto.
Como lo soluciono?
Debo realizar una actualizacion del firmware?
Saludos,
Gonzalo
Old 25th Sep 2006, 7:40 am
Default Re: E-Book Problem
I'm having the same problem as well. Anyone have a fix for this?
Old 16th Feb 2011, 11:51 am
Default Does that player support any special formats ?
Or is it just a plain txt file ?
If so that its probably the CR and LF in the file that mess things up.
Post of the the txt files as an attachment and we all could have a look at it.
Best solution is to probably strip the text file of any formatting (with MS word or OpenOffice) and then export it again as raw text. Might still look messy depending on how many characters fit into one line.
Regards
Nicolas
e-book crazydog Support and How To 5 16th Feb 2011 11:46 am
problem with e-book Aiu Support and How To 2 18th Jan 2007 11:15 pm
telephone book n2sins Support and How To 4 30th Dec 2006 7:58 pm
(Solved) E book Laurence Support and How To 5 8th Oct 2006 6:05 am
how can i read e book s in this mp4 Support and How To 2 8th May 2006 7:22 am
