mp3 lcd problem
Old 25th Oct 2006, 7:52 pm
Default mp3 lcd problem
can anyone help me with my mpxplayer... i have this nano 1.8 lcd tft, 1gb memory samsung 637, ATJ2085W.. and the lcd seems so bright i can't read what's on the screen... now the question is can i get the display driver from another firmware and replace the driver of the working firmware?
Old 25th Oct 2006, 9:14 pm
Default Re: mp3 lcd problem
rick , have you tried adjusting the brightness setting? Go to Sys Tools >> LCD Set >> Brightness. There you can set the brightness of the player. If the problem still persists, i'll suggest you contact your seller on the problem. Flashing in someone else's firmware would very likely kill your player.
Old 25th Oct 2006, 9:17 pm
What you can do is use "Firmware Modifier" (downloadable from http://www.mympxplayer.org/firmware-modifier-df17.html) to open your .bin firmware file. In there, there is a setting to increase/decrease the contrast.
Try that and let me konw of the result.
Old 25th Oct 2006, 10:43 pm
@ lattesurf
yes i done that but still its so bright.
@ admin
i done that also but still its so bright i had to incline the player so that i can read the lcd, i also tried other firmware version and it displays the right brightness but my player cant be detected by windows so i have to do the recovery process again, and one thing the display on my lcd is not displayed correctly all the letters are on the right side its like the player is facing back at me...
heres my players info
MP-752-SL Main V 1.1 Knife 05/207
Samsung637
ATJ2085W
Screen Info CD50012A-0AL TFT
it has 1 gig memory and 1.8 LCD the earphone jack is located in the bottom and the usb jack is on the right side.
BTW this is the firmware im using right now
http://www.mympxplayer.org/firmware-...ack-df257.html
Old 26th Oct 2006, 6:35 pm
up
Old 6th Dec 2006, 3:48 am
hello rick
please can you backup your mp4 ,and send me the firmware i hink we have the same thanks
