-   -   Problem with ipodready mpeg-4 with mp4 player (http://mympx.org/forum/support-how/34728-problem-ipodready-mpeg-4-mp4-player.html)
olanz 26th Oct 2006 5:10 pm
HI, i was having a problem on how to convert some music file, already it'an ipodready music files in MPEG-4 but my mp4 player is not recognising them, i tried to convert it to AMV file and the converter won't either. plz what do you suggest i do to fix this problem.
lattesurf 26th Oct 2006 5:56 pm
Re: Problem with ipodready mpeg-4 with mp4 player
olanz , you'll probably need to use an MPEG4-to-MPEG1 converter, then use the AMV converter and convert MPEG-to-AMV.
As the player only reads .AMV video files not MPEG4, and the AMV converter only reads MPEG1 files as input, not MPEG4.
You should be able to find a suitable MPEG4-to-MPEG1 converter at download.com or maybe in the downloads section here (i'm not sure)?
Hope this helps.
jp 26th Oct 2006 7:10 pm
"Super" Freeware video converter can be downloaded from the following site:
http://www.erightsoft.com/SUPER.html
A link to the download area is located at the bottom of the page and not easy to spot. If you have difficutly finding it, search the page for the word "download" and you should locate the link near the bottom.
olanz 27th Oct 2006 8:02 am
Thanks guys, your tips works fine erightsoft super converter is great and do the magic thanks JP. also lot of thanks to lattesurf.
