Language Problem !
Old 28th Oct 2006, 11:06 pm
Default Language Problem !
Hello I'm New : I recently put that 200 Image theme on my Ipod Clone nano (LSD_504_02 , ACT_V3.5.37, WILSON, and 1.5 Screen ). The Images are fine it just now it's in Chinese Language on the menu and I read and speak English. How do I change it to english also can this be done in the menu some where. I did Back up my firmware before loading the Bin file with the new images.
Thanks Alot !
Old 28th Oct 2006, 11:38 pm
Flawsey_Bee
Go to the settings menu and select 3rd from the top and then second from the top will give you English.
Old 28th Oct 2006, 11:44 pm
Default Re: Language Problem !
Thanks with the quick response. This website/forum is the ultimate help and resource. :mrgreen:
Old 29th Oct 2006, 1:31 am
For future firmware updates, what you can use is Firmware modifier (downloadable from here).
Run Firmware Modifier against your .bin file and it let's you change the default language to ENGLISH. Save the file and any future firmware updates with this .bin file, it will automatically default the player's language to ENGLISH.
Hope that helps.
Rizone 16gb mp3 player language problem very_lame Support and How To 1 9th Oct 2009 8:56 am
Change the language? Mystikal Support and How To 0 19th Jan 2008 2:08 am
Language problem... gtp300hp Support and How To 9 5th Feb 2007 2:23 pm
How to convert a DVD with another language Timmy Video related 1 19th Sep 2006 2:19 am
Language display problem nizcom Miscellaneous 3 10th Jul 2006 6:47 am
