-   -   RE: Help for firmware (http://mympx.org/forum/support-how/34796-re-help-firmware.html)
easylim 31st Oct 2006 8:43 pm
Re my MP4 problem, Lattesurf (thanks!) advised to reformat my player. Problem is I did not back up my firmware (moron that I am). I've attached pictures of my player - 1.8" screen game player look-alike. So anyone with the same model, please help with firmware, or point me in the right direction.
Thanks...easylim
Resubmit. Hope you can view images this time.
http://i145.photobucket.com/albums/r...x/P1010002.jpg
http://i145.photobucket.com/albums/r...x/P1010003.jpg
lattesurf 31st Oct 2006 10:35 pm
Re: RE: Help for firmware
easylim , what happened to your player? A normal memory format would not remove your firmware, unless you used the Upgrade Tool?
easylim 1st Nov 2006 12:35 am
Hi Lattesurf. Thanks for your quick response. To be honest, I don't know. My niece is now helping me to rectify it as I'm totally illiterate. We thought we should get the firmware in hand in case we wipe out stuff. As I write, my vendor has emailed a file that hopefully has the firmware. BTW, what is S1fwx?
tadad1 1st Nov 2006 1:22 am
easylim, I have a sneaking suspicion that your player is running the 9.0XX series firmware and if so s1fwx is not going to help as it can not repair the firmware to make it viable. If the supplier is sending you a copy of the firmware it will most likely be a full version which should recover your player.
If the firmware is you are being sent is no good let me know as I have a Full 9.0.43 for 1.8 LCD that may work for you.
easylim 1st Nov 2006 3:37 am
Thanks, Lattesurf. Will need to catch hold of my niece to help me with this. Let you know in a couple of days. May need to take you up on your offer.
MS MP4 1st Nov 2006 7:14 am
tadad1 can you send me this 9.0.43 firmware for 1.8" player.Thanks
easylim 8th Nov 2006 12:07 am
A note of thanks to Lattesurf & Tadad1. My MPX player is now up & working again. You guys have been very helpful. THANKS!
