Problem with speaker!
Old 4th Nov 2006, 11:38 am
Default Problem with speaker!
Tengo un pequeño problema de hardware con mi reproductor mp4...
Al empezar un tema... a los 3 segundos empieza a escuchar el tema por el altavoz del reproductor y cuando no tengo el audicular puesto, me figura en la pantalla que lo tengo conectado. En fin... pienso que tengo problemas con el firmware...
El reporductor en si, un ipod nano clon...
con la memoria sansung de 2gb
el procesador... atj2085h ... algo asi...
si alguien sabe como arreglar eso... estaria muy contento!!! me es muy molesto
English:
I have a small problem of hardware with my reproducer mp4…
When beginning a subject… to the 3 seconds begins to listen to the subject by the loudspeaker of the reproducer and when I do not have audicular position, it appears to me in the screen that I have it connected. About aim… I think that I have problems with firmware…
The reporductor in if, ipod nano clone…
with the memory sansung of 2gb
the processor… atj2085h… something thus…
if somebody knows like fixing that… i will be very contented! he is to me very annoying
Speaker Replacement? ALP1987 Support and How To 4 9th Jan 2009 9:58 pm
RK2608 Speaker Bug mustang50l Mods and Themes 8 18th Sep 2008 11:54 am
built-in speaker problem? (3rd gen ipod clone) starthepirate Support and How To 0 24th Aug 2008 2:22 pm
Can i changed the speaker of a mp4?? tcu212 Mods and Themes 1 3rd Apr 2008 9:16 am
Problem with external speaker. Spartan-088 Support and How To 3 2nd Mar 2008 9:53 am
