battery does not recharge
Old 4th Nov 2006, 12:06 pm
Default battery does not recharge
This problem could be so silly. But i do not know why the battery does not recharge. I plugged the cable either in the USB port of my PC and in the recharger. Ive tried more than 8 hours, but the batery is still empty.
I checked whether in the set-up is there any option of charging.
Could someboby help me?
Old 4th Nov 2006, 5:04 pm
gregoriocarbajal, The problem could be the usb cable or the battery may be faulty.
The player must be turned on for the battery to charge.
When you plug the player into the usb does it run normally?
If not then the cable is most likely the problem. If it does then the battery could be dead in which case you need to send the player back for replacement or replace the battery yourself.
ME2 Mp3 Mp4 Battery gloriaharvey Support and How To 4 6th Nov 2007 11:13 am
Recharge problem blackknife Support and How To 8 6th Sep 2007 7:13 am
[Solved] Desperately need help with battery recharge :( yenahs Support and How To 6 10th Aug 2007 6:11 am
Battery that not recharge wlazio2000 Support and How To 10 6th Jan 2007 1:18 am
wilson 1gb digital mp4 player will not recharge dopefisher11 Dead Players 15 13th Dec 2006 3:17 pm
