[solved] player play songs as MONO not STEREO sound
Old 6th Nov 2006, 1:39 am
Default [solved] player play songs as MONO not STEREO sound
anyone plz help with this my MP4 player play songs as MONO not STEREO sound and i doubt that the problem is in the Headphones ..
can anyone hlp me wiz this problem plz !!
Old 6th Nov 2006, 2:06 am
SHouSHa,
I would strongly recommend trying another set of earphones just in case though.
Generally the majority of these players don't have a "mono/stereo" setting within the player itself. Majority of the problems are either with the earphones or the earphone input into the player isn't working properly.
Try another set of earphones and see what happens.
Old 6th Nov 2006, 11:07 pm
Default Re: player play songs as MONO not STEREO sound
Is the sound coming through both headphones or just one? Mine came through just one... I had to solder the audio jack component back onto the board properly to get it working properly.
Testing with another set of headphones is always the best first course of action, though.
Old 7th Nov 2006, 10:16 pm
thnx for ur hlp guys ..
i actually bought new earphones and they work perfectly even better than the old ones and the most important thins is that the sound now is STEREO
[solved] How to upload songs to my player? jaetyl Support and How To 6 29th Nov 2009 2:21 am
[solved] Playing songs sound shocking christine Support and How To 3 6th Nov 2007 1:23 am
songs duplicate and only 25 songs play cardinalbird Support and How To 4 6th Nov 2006 8:24 pm
Ipod Nano MP4 Player wont play in stereo mode prodigi General Discussion 2 2nd Nov 2006 7:11 am
Songs doenot play in my MP4 player srinathtk Support and How To 2 16th Oct 2006 1:05 am
