Convertion problems!
Old 6th Nov 2006, 1:34 pm
Default Convertion problems!
I conver AVI files to amv and then play them on my mp4, but what happens after that is that, the picture, screen or image (whatever you wanna call it) goes split and shows green and purple shades of colours, and also the sounds un-syncs with the bad images >_<
what can I do... I only succeeded in getting a prob=per conver few times ...help
The only way I found to solve it (sometimes), is by cutting the videos in 10 minutes each.
I have a 1.5inch screen mp4~
Old 6th Nov 2006, 8:22 pm
zalude
What convert tool version are you using?
For 1.5 inch player, it's best to use the 3.68 convert tool.
Set your setting as 96 x 64 and it should convert fine.
Have a look at this tutorial here:
http://www.mympxplayer.org/how-to-co...-368-vt32.html
Old 6th Nov 2006, 9:07 pm
zalude,
Have you installed any codec packs?
If not you can download the K-Lite Mega Codec pack from HERE
For a 1.5 inch LCD I think 128x96 (widescreen) or 128x128 (full screen) would be better than 96x64 which is more for a 1.2 screen.
Old 7th Nov 2006, 2:56 am
Default Re: Convertion problems!
Ah...I'm using the 3.68 one but the picture are so small while the 4.05 is GREAT but my MP4 hang after playing the 4.05 version convertion for 3 seconds. Donno why but the 3.68 version i got cannot change the size of the picture and now i can even uninstall it from my PC. It says that FATAL ERROR DURING INSTALLATION. Any ideas to fix thix? And my screen size is... i donno...maybe 1.2inch? ops:
[img=left:afb175f747]http://i142.photobucket.com/albums/r113/xyz_cityhunter/aca.gif[/img:afb175f747]
This is what i''m doing with new and unknown brand of MP4/MP3 Player........
Which is the ENDING where everything starts to fall apart........
Old 7th Nov 2006, 3:18 am
ctht,
To uninstall it you need to delete the folder from the Program Files folder then open regedit and got to
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Uninstall. You will find a series of subfolders with alpha numeric names like this {7784A172-61F1-445E-8368-601607E0DD22} click on each one until you find the entry related to MP3 Player Utilities 3.68 displayed in the right panel, then delete this folder. Then do the same here HKEY_CURRENT_USER\Software\Microsoft\Installer\Pro ducts\
You should now be able to install a new version.
If 3.68 is not working for you and your player is 1.5 then try using version 4.0 HERE. Once you have it installed go to the AMV Converter folder and open AmvTransform.ini in notepad and change CHIPTYPE=0 to unlock the 1.5 settings.
How to get a smaller convertion jungleb Support and How To 2 19th Apr 2007 4:07 pm
DVD to AVI convertion problems seanamos Video related 0 8th Mar 2007 1:18 am
MP4 Problems mark2 Dead Players 18 2nd Feb 2007 11:01 pm
Problems with LCD sodiumray Support and How To 0 22nd Dec 2006 8:02 am
Cannot install AMV convertion tool 3.68 sharonx87 Video related 8 24th Jul 2006 7:05 am
