Unknown Flash error - firmware is 9.0.43
Old 11th Nov 2006, 3:33 am
Juz Juz is offline
Default Unknown Flash error - firmware is 9.0.43
I have extracted the firmware , and change some of the images but when I try to imprt the firmware I get 'unknown Flash Error'
I am using Disk tools 3.57
My firmware is 9.0.43
I cant even import the original unchanged Firmware file, even though it is not corrupt.
Is there a write protect on the firmware, or is there a different firmware flasher I can try ?
Old 11th Nov 2006, 6:35 pm
Default Re: Unknown Flash erro
Juz , from what i know, the version 9.0.xx firmwares does not work well with the extractor and flasher. Currently it only supports the versions 3.x firmwares.
There is really nothing much you can do to your player at this moment. We are still waiting for someone to do up a proper extractor & flasher for the 9.0.xx series.
China Ipod 8gb unknown flash and dead Chiro Dead Players 3 22nd Aug 2007 10:49 pm
unknown flash error gos1 Support and How To 3 10th Feb 2007 6:25 pm
Unknown flash error! fiollhoip Support and How To 7 15th Dec 2006 3:35 am
Unknown flash error siloveup Dead Players 6 26th Oct 2006 1:28 pm
unknown flash error!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! dthdabomb89 Support and How To 10 25th Jun 2006 2:33 am
