The system cannot read from the specified device
Old 16th Nov 2006, 1:47 pm
Default The system cannot read from the specified device
here is the errors :
$e
connect to device 'E:\'...
init device...
set device to f-mode...
get info from device...
ic version = 0x0000
storage info = 0x0602, 0x0001, 0x0000, 0x0000
device = 'S1 Mp3 Player'
bootflash type = 'F285'
brom version = 3.0.80
firmware version = 9.0.48
read boot record...
detect firmware size...
error: The system cannot read from the specified device.
read flash...
write to file 'dump.bin'...
filename = 'dump.bin'
filetype = afi
md5 = 8D6CA4FABBA750944EBD446E4FCD3C74
file id = 'AFI '
vendor id = 0x6977
product id = 0x6552
version = 9.0.48
date = 00/00/0000
| BRECF285.BIN | | 16kb | | F285 | | B | | F1C85F6D |
| SYSINFO.BIN | | 192bytes | | | | | | D5D9805B |
filetype = unknown
disconnect from device...
success.
Old 16th Nov 2006, 2:15 pm
Zurky, Your player is using the 9.0.XX series firmware. At the moment there is no way to make a working backup of this firmware. The s1fwx tool will need to be upgraded to do this.
Old 14th Dec 2006, 8:45 am
Default Re: gloree mp4 player.
you can use ATJUPLOAD to dump firmware 9.0.xx you find it here http://www.mympxplayer.org/atjupload...tor-df405.html
i need you dump file because my mp3 is dead write my email is hosenfan@o2.pl.
Help. Read or Write device information failed XoLoX Dead Players 2 20th Oct 2007 11:38 pm
"Read or Write device information failed" serp Dead Players 22 8th Aug 2007 12:57 am
s1fwx says system cannot read from the specified device The Great Simonski Support and How To 2 15th Mar 2007 3:58 pm
Read or write device information failed!Please exit the... Pissy Dead Players 2 6th Dec 2006 3:44 pm
Read/write error...check if device is connecting... Pissy Dead Players 5 5th Dec 2006 4:44 pm
