YM5387WZSZB 2GB MP4 player problem
Hi, i've just bought this iPod lookalike 2GB MP4 player from a store in China.
The problem is when i put songs in the player, it duplicates folders and files with wierd filenames and symbols. :shock: Then i reformatted it with FAT32 and FAT and tried copying mp3s. But when i play the songs, it could only get past about 12 tracks out of 20 tracks. It crashes and restarts everytime i try to get past track 12. :( Issit a known problem, how can i fix it? Should i try to extract the firmware and reinstall it? i'm new to this, please help... Serial no.: YM5387WZSZB Model no.: A1137EMC No.:2066 it looks like this. Thanks! |
Re: YM5387WZSZB 2GB MP4 player problem
nicad , what i'll suggest is to perform a format on your player first. There is a guide on doing this Here.
Next, once formatted, extract and repair the existing firmware in your player. The guide is Here. Now, keep a copy of the repaired firmware safely. Using it, re-flash it back into your player. The guide is Here. See if these steps solves the problems. |
hii...
I have the same as this mp4 player can anybody send me this mp4's dumb.bin thanx |
| All times are GMT -7. The time now is 5:59 am. |
