help in recovering ACT_3.5.35 firmware
Old 18th Nov 2006, 9:21 pm
Default help in recovering ACT_3.5.35 firmware
Hi,
I'm a newbie here. I would like to ask some help in recovering my MP4's firmare ACT_3.5.35. The problem started when I tried to update its firmware from a file I downloaded on this site. The screen display became different and blurred and most of the text are now translated into line graphics.
I just would like to put it back to its usual firmware version....
Please help....
Looking forward for your assistance,
Allan (Philippines)
Old 19th Nov 2006, 1:14 am
Default Re: help in recovering ACT_3.5.35 firmware
Allan , do you have a backup of your original firmware? If yes, use it to flash back into your player.
Or else, you will need to try various firmwares in the downloads section for your screen size until you get a compatible one.
Old 19th Nov 2006, 4:14 pm
Hi,
Thank you so much for your reply....
No, I don't have a backup of my firmware.
It was only when I found out that I had to do that.
I was hoping I could get one from your site.
Please help me out....
Cheers,
Allan
Old 19th Nov 2006, 5:37 pm
Allan , if this is the case, you have no choice but to try every single firmware dump in the downloads section Here.
There is no way of telling you which firmware will work with your player, as the version number is not properly controlled by the manufacturer. So even an older or newer version number might work for you.
Old 26th Nov 2006, 4:37 am
hi allanc10 i have same prb so plz also tell me the way if u found .
recovering firmware information compostcorner Dead Players 0 17th Sep 2009 10:27 am
I got Error while recovering my dead mp4 dragongel General Discussion 0 9th Sep 2009 5:47 am
Recovering firmware Derekus Dead Players 7 28th May 2009 12:14 am
Firmware MP693C-SL SC85052A ACT_3.5.35 ovalles Dead Players 0 21st Nov 2007 5:03 pm
Seriously Need Help with recovering my DEAD MP4 player atz Dead Players 0 5th Jan 2007 8:20 pm
