Strange problem with files
Old 20th Nov 2006, 9:37 am
MBA MBA is offline
Default Strange problem with files
Hello everybody
I purchased an 1.8" 4 Gb MP4 player (unbranded, it looks like this one Click the image to open in full size. but screen is rotated 90 degrees) from an italian ebay shop.
The reader works quite well, but I'm not able to browse songs. I can browse folders but no files are shown inside (the are present). I tried to format using FAT16 (64kb allocation), FAT32 from WinXP and from Mac, but the problem is always the same. In addiction, it doesn't remember which song was playing when the reader turned off and always starts from the same song. It is quite frustrating. I already tried putting only a few songs on the reader, but the behaviour is always the same. Can anyone help me solving this issue?
Thanks in advance
Mario
Old 21st Nov 2006, 12:32 am
Default Re: Strange problem with files
MBA , currently these players do not support file-browsing, only folder browsing. So when you go to the browser list, all you can see are the folders that stores the mp3 files. There is nothing much you can do about this.
Regarding your second problem, try to stop/pause your music, exit the music program, then off the player (not the main switch, but press & hold the play button). See when you turn the player on again, does the music continue from where you stopped off.
Old 21st Nov 2006, 12:45 am
MBA MBA is offline
Thanks a lot. Unluckily, i tried what you suggested but no way: it always starts from the beginning of the first song! Even when I select a different folder, it comes back to the first song.
See you!
Mario
strange problem today!! help! ikarus2007 Support and How To 7 22nd Jun 2009 2:15 am
Strange problem with my MP5 Astireloth Support and How To 0 22nd Apr 2009 11:20 am
Strange Problem nanocopyuser Support and How To 3 3rd Apr 2007 8:47 am
Strange Problem delerium69 Dead Players 3 26th Jul 2006 4:00 pm
Strange Problem ! manu1991 Support and How To 3 16th Jun 2006 2:29 am
