ACE A038 Firmware Problem
Old 21st Nov 2006, 2:56 am
Default ACE A038 Firmware Problem
I've got ACE a038...one time it kept on being disconnected from my pc and some sort of VOIP problem was indicated in the message and recommends upgrade...hen I remove it from USB then connect again it will work fine and then after sometime the cyme msg appears again...
I tried downloading a firmware from this cite which is supposed to be an upgrade of the existing firmware...after I used it to upgrade the firmware, the unit just blacked out...hen I durn it on the screen lights up to blue then blinks on and off...but only blue screen...
kneed help...
Old 21st Nov 2006, 4:20 am
Default Re: ACE A038 Firmware Problem
rcgarrido , do you have a backup of your original firmware? If so, use it to flash back into your player.
If not, you will need to try every firmware dump in the downloads section for your screen size until you get the right one.
ZX-6330N firmware problem Zulu007 Firmware 4 27th Apr 2008 4:36 am
mp4 problem ...and firmware leelaah Dead Players 0 22nd Jan 2008 12:33 pm
firmware problem bammy3942875 Dead Players 6 9th Apr 2007 8:16 am
Please HELP Firmware problem ecastor Dead Players 6 19th Dec 2006 8:34 am
