Need help: Firmware update!
Old 21st Nov 2006, 1:19 pm
Default Need help: Firmware update!
Hi! I have a 512Mb Blaze Mp4 and I'd like to upgrade the firmware version (Acts16d_13 2005/06/01 ws.3.2.16 2005-12-06 Wilson and Co.)
]Mercado Libre
The player works fine, I just want to try something new, but... I donīt want to ruin my player, so what do you recommend?
Old 21st Nov 2006, 4:22 pm
Default Re: Need help: Firmware update!
sek300 , first up, never ever flash in another person's firmware unless your player is dead and you are performing dead player recovery. You are more likely to kill your player straight.
There are no significant benefits in newer versions, but if you want to try something new, i'll suggest that you theme your firmware instead.
The full guide is Here, from extraction to modification to flashing. Always remember to use your own extracted & repaired firmware for theme modification.
Old 27th Nov 2006, 11:29 am
Lattesurf, thank you very much for the advice. That's the smartest option isn't it? Thanks again.
Old 27th Nov 2006, 3:31 pm
sek300 , well technically yes. Just a wrong firmware update and that's it, you'll be tearing your hair out trying to recovery your player.
Firmware update Oman Support and How To 0 4th Aug 2008 11:48 am
I need to update firmware gaudier Support and How To 2 29th Oct 2007 1:28 pm
Update the firmware Help!!!! _AXS_ Support and How To 1 7th Jan 2007 1:42 am
firmware update milindbendre Video related 1 4th Aug 2006 7:01 am
Firmware update or not cherva Support and How To 5 4th Jul 2006 4:58 am
