sound
Old 25th Nov 2006, 8:46 pm
Default sound
using AMV Converter 3.68, converted Quicktime video clip from my camera (after loading codecs) video plays ok but sound is garbled, cannot change bit rate of sound, is there a way to change bit rate?
Old 27th Nov 2006, 12:50 am
jtaiariol,
The AMV Convert Tool doesn't have that many options unfortunately.
What you can try is to conver the Quicktime video to an AVI or something. Then you can try converting it to .AMV instead. It might be that the Quicktime codecs you have installed doesn't work 100% with the AMV Convert Tool.
Old 27th Nov 2006, 9:14 am
Default Re: sound
can you suggest a good mov to avi conversion software?
Old 27th Nov 2006, 1:38 pm
Default Re: sound
I use WinAVI which can be downloaded here
http://www.winavi.com/en/download/download.htm
Dave
Old 27th Nov 2006, 7:55 pm
Default Re: sound
avionik88,
it seems the free version doesnt convert 100%, do you use free or registered version?
Old 27th Nov 2006, 8:38 pm
jtaiariol, Try here:
http://www.videohelp.com/mov2avi
Old 28th Nov 2006, 6:33 pm
Default Re: sound
tadad1,
success....mov2avi permits audio bitrate revision and after converting to amv will plays a-ok in my player....somewhat labour intensive, however working....thanks again for all your help
No Sound rippedoff Dead Players 2 28th Aug 2007 4:04 am
No sound after AMV convert pr_wainwright Video related 1 28th Jun 2007 12:54 pm
No Sound!! haseebanjum Support and How To 4 19th Sep 2006 6:33 pm
Bad Sound with 4.00 Bad Visual with 3.68 Eks Bee Support and How To 2 12th Jul 2006 4:48 pm
AMV sound antdroide Video related 2 11th Jun 2006 2:55 am
